Cooling Mode blows hot air
PatrickWSteward
Just tried installing nest from an old Honeywell thermostat that powers HVAC (Heating / Cooling / Fan).
Heat pushes not hot air.
Cool pushes hot air 
Attached is the current nest configuration and back of the old thermostat with wire configuration...
Your nest thermostat is not set up properly for your heat pump. You can ignore the white jumper wire between Y and W, however, the white wire that was attached to O on your old thermostat needs to connected to the O/B of your Nest thermostat.
Start your setup over, the wires I use are:
Red on R to Nest R.
Yellow on Y to Nest Y1
Green on G to Nest G
White on O to Nest O/B
Your equipment type is Heat Pump.
 Now the Nest works best with a Common wire and your cable has an unused Blue and Brown conductors.  You can check the HVAC equipment and see if the blue or brown wire is attached to a C terminal.
Good luck!
Ken, The AC Cooling Wizard
9 REPLIES 9
Red on R to Nest R.
Good luck!
That did it - up and running properly now!  Thanks so much for the quick response!
Patrick
That is good to hear Patrick.  If you can, choose my answer and mark it “recommend this answer” and while there, tap that Kudo button. Thank you.
Done!
I will all look to see if the HVAC unit has brown/blue/common connectors when I get access to it (condo unit) but glad to see the wiring is already there!
Thanks again!
Patrick
Patrick, if you live in a Condo, your air handler is likely inside your condo unit. In an alcove perhpas?
AC Cooling Wizard
@PatrickWSteward, I am glad to hear that your concern was fixed. Thanks @CoolingWizard, for your help. You both did a great job!
Please let me know if you have other concerns or questions as I'm willing to assist you from here.
Jeran
Thank you for helping out on this thread, CoolingWizard!
Hey there PatrickWSteward,
I'm just checking up on this thread, do you have any more questions or need any additional help?
Jeran
Jeran
Do you have any more questions that we can address?
Thank you,
Jeran
Chiming in — @PatrickWSteward, we haven't heard from you in a while so we'll be locking this thread if there is no update within 24 hours. If you need assistance or want to discuss topics, feel free to start a new thread.
I appreciate your help @CoolingWizard and @Jeran.
