Doesn't turn on heat, cooling woks fine
aman2709
The nest thermostat works when the temperature is set below room temperature.
But the heater doesn't turn ON when the temperature set above the room temperature.
AxelD
Hi aman2709,
Sorry to hear that your heating is not turning on, but no worries, help is here. I'm leaving you this article Troubleshoot strange heating or cooling behavior, it contains some troubleshooting steps. In case it doesn't work for you, feel free to fill up this form and an agent will contact you as soon as possible.
Axel.
