Dropped nest thermostat not working, battery disconnected
Ashbournekiwi
Hi,  my thermostat 3rd generation fell from wall. Went blank, not connected . After trying all the usual,  I took back off, then found video to get to battery. ( which I didn’t know it had).   Had to take off  white plate, carefully remove back plate.    This has a ribbon attached so just half flip over to get to screws to remove plate so can see battery.   The battery connection 2mm  square had dislodged. So put it back. Now all working.   Careful with screws used a Philips ooo,  and magnet holder. Hope this helps.
2 REPLIES 2
moralesvicente
Hi Ashbournekiwi
Thank you so much for posting these tips and for your willingness to share your knowledge, especially on crafting clear subject lines. They'll definitely help me communicate better and assist more people.
Regards
Daniel
mikeharing72
Glad to hear you were able to fix your thermostat! Thanks for sharing your experience and the steps you took to resolve the issue. It's always helpful to hear about others' troubleshooting methods. Your detailed explanation might assist someone facing a similar problem and I have been solved many problems from the stainless steel herb grinder.
