09-12-2021 05:46 AM
I have had this problem for some time. I turn on the heat and after about 3-5 minutes, the heating cycles off and gives me the "E24: No power to Rh wire." error. After a few more minutes, the furnace gets power back and starts up again, but then I get the E24 error again the the furnace cycles off.
My wiring (attached) if for forced air heating (oil fired) and AC. I have followed community threads in the past that suggest a fuse is out on the furnace but mine doesn't have auto style fuse to replace. I have also checked and the condensate pump is working. It seems that removing the Y1 wire helps, but I do still get it cycling, just less frequently. The widget sends me straight to the HVAC pros, but it seems there should be an easier fix.
Any help appreciated.
John
09-12-2021 08:45 AM
E24 error means the nest can't electronically detect power to your RH wire.. the reason they suggest a HVAC pro is it could be an electrical issue with the furnace itself, or something as simple as a loose wire.
09-12-2021 10:37 AM
Thank you so much for your reply. If anyone has suggestions about what I can try before getting an HVAC pro, I would grateful — especially as there are no Nest engineers in our area.
09-22-2021 02:22 PM
Hey JTC3PO,
I wanted to reach out and see if you still need any help? Please let me know.
09-24-2021 01:19 PM
Hey all,
It's been a few days since the last reply. I am going to lock the thread at this time and if you have any questions, please feel free to create a new post.
