04-03-2025 11:08 AM
My eco keeps turning on even though I am home. In the middle of the night it will turn on, therefore not letting the AC run and it gets hot. I turn it off, switch from away mode back to home and after a little bit it turns back on! This is happening more and more frequently all the time while I am home. During the day, at night, no rhyme or reason, it just switches to away mode and activates the eco.
04-06-2025 10:37 AM
Hi @ChadDenny,
Thanks for reaching out to the community forum. I'm sorry to hear your Nest thermostat switches to Away mode unexpectedly and activates Eco mode. Don't worry, we're here to help.
Our team is aware and is looking into this issue. We apologize for the inconvenience caused and thank you for your patience. I'll be sure to keep you updated on the progress and let you know as soon as we have a solution.
Sincerely,
Jonathan
04-06-2025 12:08 PM
Maybe it’s just a coincidence, but my timeframe of when my problem started appears to coincide with the last update of my nest, which was about three weeks ago. Maybe it has something to do with it, but not quite sure, but I can tell you I’ve had the nest for a while, and I’ve never had these type of problems at this frequency.
