07-15-2024 10:02 PM
I received an error code E72 on my thermostat. We checked the wires and replaced the fuses in the AC unit. The AC still will not turn on. I can't even get to the regular screen to try and just cycle the heat on so I can make sure it on the AC. Do you think it can just be the thermostat or the nest wiring no good anymore?
07-16-2024 11:42 AM
Try checking for a stuck float / bad water sensor/ blocked drain in the condensate drain path of your AC unit. Many units will remove power from the thermostat if they detect a problem with this drain.
07-20-2024 11:49 AM
Hi, @Dessertgirl25,
Thanks for reaching out to the community. I understand the E72 error code on your thermostat can be frustrating. I'll do my best to help you find a solution.
To better assist you, I have some questions related to your thermostat:
In the meantime, I recommend:
Keep me posted.
Ana.
