11-12-2022 05:31 PM
How do I stop the fan from coming on while the heat setting is on? Never had that issue with different thermostat and I’ve tried shutting down the fan on the app and nothing
11-12-2022 09:03 PM
Is your issue when your thermostat says heating there is no heat coming out? Just cold/room temp air? I’m encountering the same issue
11-14-2022 08:40 AM
No it’s just when I turn the heat on the fan comes on and I don’t want the fan turning on with the heat on
11-16-2022 10:47 AM
Thanks for posting ― let's get this sorted out.
You can turn off the fan on your Nest Thermostat display. Check this guide for more details: Fan control with a Nest Thermostat
Keep us posted.
Mel
11-19-2022 11:20 AM
Mel
11-20-2022 11:38 AM
Mel
