08-15-2023 08:54 AM
Does anyone know why the ac fan may be turning on and off about every 7 minutes. Once the cooling cycle begins it will stay on until cooling temperatures is achieved. Do I need to set the setting to different cooling mode (eco confort sleep) right now this is under eco mode. Central cooling unit with an external compressor unit.
08-15-2023 09:29 AM
Check see if you have the fan on a schedule. Good luck
08-15-2023 10:03 AM
Just checked, it appears fan setting to be on. (Turned it off and will see if this works. Thanks!
08-15-2023 09:29 AM
08-15-2023 10:03 AM
08-19-2023 10:31 AM
@Robertaerial, thanks for reaching out to us, and I'm sorry to hear about the situation. I want to check and see if you are still in need of any help or if you've already followed the Recommended Answer above. If not, please let us know so we can assist you more and make sure you're good to go.
I appreciate your help, @HVAC.
