12-05-2021 04:44 AM
Very disappointed to hear it’s a fairly common fault that the heatlinks just fail on the gen3 nests no heating at all no lights on heatlink at all completely dead and not even two years old yet replacement needed
12-13-2021 06:02 AM
Thanks for reaching out. I'll do my best to get this sorted for you as soon as possible.
Here are some helpful troubleshooting steps:
Press the button on the Heat Link and check if you have any lights on it
Check if the circuit breakers and the switches are set to on
Turn them off and then back on
Press on the button again and check for LEDs
Could you also help me with some answers to these questions?
How many zones ( thermostats ) are present in the setup?
Cristian
12-13-2021 06:31 AM
All of the things you have suggested have been done and tested the unit itself is faulty we have had the Nest for around a year and a half
12-13-2021 06:39 AM
Thanks for getting back to me. I'll open a case for this issue. I'll be sending you an email to check a few details. Check the email address linked to your community profile.
12-13-2021 07:04 AM
Email received I have included all the information and the serial number for the unit .
regards chris
12-13-2021 07:09 AM
Great. I received your reply and followed up.
01-05-2022 08:04 AM
Hey @Chrispittham,
Since you are in touch with my colleague via email, I'll go ahead and lock this thread. If there's anything else you need, you can open a new one anytime.
