Have furnace fan not run during cooling
subarudrift
Hello all!, is there a way to have the furnace fan not run during cooling? I have a simply works board that run my swamp cooler on the gen4 but I would like the furnace fan to not run during stage 1 cooling(does not run in stage 2). If there is a way to do this please let me know
Rusell
Hi Subarudrift,
Thank you for posting in the community. I understand that you'd like to know if there's a way to keep the fan off when your system is cooling. Help is here!
Here are two ways you can try to keep the fan off while it's cooling:
  • Turn off the fan schedule:
    • Open the Google Home app Google Home app.
    • Tap and hold your device's tile.
    • Tap Settings.
    • Select Schedules and then Fan.
    • Set it to off.
  • Only if you feel comfortable manipulating wires, try removing the G wire on the thermostat:
    • Turn off the breakers.
    • Gently remove the display from the base plate.
    • Then, remove the G wire
For more information regarding fan control, please take a look at this article: Fan control with a Nest thermostat.
Keep me posted.
Best regarsd,
Rusell.
