05-12-2025 12:08 PM
Nest E does not turn off fan when using the fan schedule option. I can turn the fan off and on MANUALLY. But when the Fan Schedule turns the fan on, it does not turn it off. AND you cannot turn it off manually after that without changed it to heat or cool then turning off the fan manually.
This did not happen with my old carrier, it worked. But with my new 2 stage amana where the fan is on the low setting, it does not work.
05-15-2025 04:51 PM
Hi @Ulieq,
Thanks for reaching out to the community. I'm sorry to hear that your Nest Thermostat E is not turning off the fan when using the Fan Schedule option, but there's no need to worry; I'm happy to help you right now.
I need to get more information to send you the correct troubleshooting steps. Please help me out by answering the following questions:
Any additional details you can provide will be helpful.
Gabriela
