10-11-2022 06:44 PM
I have the heat pump controller and wires listed above. When I enter the compatability settings online it says it is compatible. When I enter the same settings on the app, it says it isn't compatible and so I can't proceed. Any advice?
10-15-2022 01:58 PM
Hi blank1,
Thanks for reaching out. I'm sorry to hear that you're having an issue with setting up your Nest Thermostat. Could you share a photo of how your Nest Thermostat is wired?
Edward
10-15-2022 03:47 PM
Thanks Edward. I went around the system and said it was already setup by a professional. I linked the
Y,G,C,O/B,R to the same wires as labeled on the nest. I linked the E wire to W. I tested and Emergency heat came on manually so I assume it is working, though I don't know what other repurcussions there may be. At least the A/C is working for now.
The frustrating thing is that the online checker and the app conflict.
10-18-2022 09:59 AM
Hi blank1,
Thanks for the update. I'm glad to hear that you were able to set it up. Please observe it for now and let us know if anything comes up.
Edward
10-21-2022 10:00 AM
Hi blank1,
Edward
10-24-2022 03:24 PM
Hi blank1,
Edward
10-25-2022 05:53 AM
It's working fine for A/C. But this is in Texas, so it will be a while before we can see if it works as expected for heating/heat pump/emergency heat. Thanks for asking.
10-25-2022 03:50 PM
Hi blank1,
Thanks for the response. Were you able to test both heating and cooling after setting up your Nest Thermostat?
Edward
10-31-2022 05:40 PM
Hi blank1,
Edward
11-01-2022 06:47 PM
Hi blank1,
Edward
