Heat and AC come on using heat setting
jjc60631
Installed the Nest Thermostat using Y, R, W, G, & B as common or OB. Same colors in same configuration on furnace. Set thermostat to Heat and picked temp. Both furnace and AC come on at same time. Single stage furnace.
10 REPLIES 10
Post a picture of the original thermostat's wiring here.
You can not go by the wire colors as there is no standard
When I do a wiring check in the thermostat it says C is missing as I don’t have Blue wire plugged there. It is in OB.
I figured it out. I did factory reset and redid everything. Working fine in all modes as should!
thanks for helping me out!!
jjc60631
Not sure how to add photo. On thee we furnace main board. Red to red. Green to green. Yellow to yellow. Whit to white. Blue to common (c). There is an additional 2-wire cable, red and white. Red to yellow terminal. White to common (c).
Click on the camera icon
Do a factory reset to the Nest Thermostat and set it up again using the Home App.
Connect everything one to one with the blue wire going to C.
Then select the following when asked in the app.
R, G/G1, Y/Y1, W/W1, and C
That’s exactly how I did it 2nd time and all good now!! Thanks for the help!!
Ryan_G
Ryan
Ryan_G
Have a great day.
Ryan
Ryan_G
Hey jjc60631,
Thanks for being here at the Google Nest Community.
It's great to see that everything seems to be working now. We'll continue to observe how your systems works in the next couple of days and let us know how it goes by replying to this thread.
We really appreciate you always helping us here in the community, Patrick_Caezza.
Ryan
