01-10-2022 12:43 PM
Nest thermostat showing H71 error
Nest heat link showing no lights.
Powered off/on
Held button down for 20 seconds
No change
Can you order a replacement?
01-12-2022 06:06 AM
Hey @Arbiter389. Thanks for reaching out. I'll do my best to get this sorted for you. Could you also help me with some answers to these questions?
How many zones ( thermostats ) are present in the setup?
01-17-2022 03:28 AM
Hi, I wanted to check in. Do you need any further assistance? If so, make sure to let me know.
01-18-2022 03:57 AM
It's been a while since this thread was last updated so I'll go ahead and lock this thread. If you're still experiencing problems, please feel free to start a new thread and we'll be happy to help.
