01-08-2022 07:32 AM
Hi
I have two nests thermostats (one for upstairs and one for downstairs) with the links connected next to each other with the valves. They've both been installed for about 18 months but today i've noticed the downstairs one has stopped working. the thermostat had powered off and when i checked the link one had no lights (seemingly no power) and the other is working as expected. It appears to be very similar to the issue described here:
Because both heat links are powered from the same source and one is working i know its not an issue with fuses etc. I have tried pressing the big round button but there's no response. no lights show at all on the heat link. There has been no work on the heating or electrics, this has happened out of the blue.
Please can you help.
01-08-2022 10:53 PM - edited 01-08-2022 10:54 PM
Whatever gives power to that thermostat is the issue. If there is power to stat ( 24 volts detected with volt meter) on R and C then stat is bad
01-09-2022 03:57 AM
Checked on the heat link with the multimeter: 240v ac across L and N. 0v DC across T1 and T2 going to the thermostat. Also no lights on the heat link at all. By comparison, the other heat link next to it, also 240v across L and N and about 12v DC (11.6) across T1 and T2, green light shows on heat link and thermostat is happy.
Heat link is dead, just need to know what i can do about it. Other posts suggest this is a fairly common issue.
01-11-2022 04:40 AM
Hi there. Thanks for reaching out. I'll do my best to get this resolved for you. Can you help me with some answers to these questions?
How many zones ( thermostats ) are present in the setup?
01-11-2022 11:28 AM
How long has your thermostat been installed for? Since August 2020
Did the issue happen during the installation? No
Is there any error on the Nest thermostat display? Once charged back up - E4
Have you had any power cuts recently? No
Have you had any work done on your electrical or heating systems recently? No
If yes, was the power properly restored at the fuse board after work was done? -
How many zones ( thermostats ) are present in the setup? 2 (There are upstairs and downstairs zones with a heating valve controlling each. We have two thermostat/heat links, one for each valve). The other one is working fine.
01-12-2022 06:52 AM
Hey @martynjjones. Thanks for the details. I'd like to open a case for this issue. Can I send an email to the address linked to your community profile?
01-12-2022 10:42 AM
Yes of course, that would be great thanks.
01-13-2022 10:52 AM
Hey @martynjjones,
I've created a case for you and sent you an email right now, please check your inbox and let me know if you've received it.
01-13-2022 11:06 AM
Hi, I have thanks you and have filled outcthe form.
01-14-2022 09:48 AM
01-17-2022 01:13 PM
Hi I did the next step but haven't heard anything more.
01-18-2022 06:04 AM
Hey @martynjjones. I just sent you a follow up email.
01-20-2022 06:14 AM
Hello again. Since we've managed to resolve the issue over emails, I'm going to close this thread. Should anything come up, feel free to open a new one.
