Heat on but not at home
Pickers
Home/Away set to on BUT heat came on (following learned schedule) unnecessarily whilst we were not at home. Why?
6 REPLIES 6
I wanted to follow up and see if I could be of any help. I found an article with more details on Home/Away. Please let me know if you have any questions from here, as I would be happy to take a closer look and assist you further.
Pickers
Thanks, Jake.
I have a 3rd gen ‘learning’ Nest.
I find the ‘help’ on the thermostat confusing.
I have set a schedule; does that overide the ‘learnt’ demands, or is the learning merged with the set schedule? How is it merged? Do I need to set a schedule at all? How is the learnt pattern affected by sensed movement in front of the thermostat? There’s an algorithm there somewhere, but I’m blowed if I can figure it out!
We’ve just returned from a night away from home. I set the stat to a low temperature on departing, only to find the heat was on - unnecessarily - on our return this afternoon. No learning there?
If you have the learning enabled, it will create a schedule for you based on what is has learned. If you are wanting to have a schedule you set be the one that is followed, I would recommend disabling the learning feature. Here is an article with more details.
EmersonB
Hello folks,
@Pickers I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
I appreciate the help, Jake.
EmersonB
Hey Pickers,
