Heat won’t kick in
Mommabear1225
Ever since there was a Wi-Fi outage the heat won’t kick on. I’ve both restarted and reset the nest e and it didn’t help. I’ve even tried unplugging the Wi-Fi.
Hello Mommabear1225,
I'm sorry to hear you're having issues turning on the heat with your Nest Thermostat, and I appreciate all the steps you've taken. Let's see what's going on.
Could you please share with us a photo of your thermostat's wiring? When was the last time you changed the furnace's air filter? Note: A clogged air filter can cause an HVAC system to not activate. Also, please check its power readouts on your thermostat's Technical Info settings.
I'm checking back in — how's it going? A power-related concern could cause your thermostat to lose its charge and stop controlling your system. If your thermostat is not turning on, try charging it for an hour using a USB charger. Also, you might have seen a wiring report or a message code. This report would help us identify what's going on, and if there is, please let me know so we can move forward.
