10-28-2023 01:48 AM
I'm trying to install my HeatLink on a Vaillant VUW 280/3-5.
Where do I connect my HeatLink heat request?
If I put it on the 24V output on the board, the boiler turns off the moment I request heat.
The old thermostat worked with a 230V connection, and I wonder if I can connect 230V output from the boiler to port 2-3 on the HeatLink?
10-31-2023 05:10 AM
Hi @Empira , thanks for reaching out to us here. I would be happy to try and assist.
Please check out this installation guide for the Google Nest 3rd Generation Learning thermostat. It explains what terminals require what wires and has examples for different types of systems.
11-03-2023 05:11 AM
Hi, I wanted to check in. Is there anything else I can try and assist with?
11-03-2023 05:12 AM
Hi Alex,
I just wired it with 230V and it seems to work. It would be nice to have this information in the manual.
11-03-2023 05:14 AM
That's great to hear. Make sure to let us know here if anything else comes up that you need assistance with.
