Heater won’t kick on
ahiji
My apartment complex just installed a Nest Thermostat. I set it up on the app and ran the heater for the first time today. I put it on heat, but it’s only blowing cold air. I can’t get the air to be warm. Does anyone know how to fix this issue?
Houptee
They need to add a C wire to the Nest.
Do you have AC and heat with this system?
I see they used blue wire for AC ( Y terminal) that is usually a yellow wire but it could be they used blue for the AC wire.  Usually blue is for C common wire but without seeing the other end of the wires at the furnace no way to know. Can you access the furnace or is it off limits to tenants?
There could be some other problem with your heat not coming on but in the long term without a C wire the batteries will wear out often since it gets power from R red and C common to keep Nest powered up.
Jhonleanmel
We appreciate your help here, Houptee.
ahiji, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Mel
Mel
EmersonB
@ahiji just one quick final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need help, I would be happy to keep it open. If there's more we can do, just let me know.
Thanks for lending a hand, Mel and Houptee.
