Heater won’t turn on after power outage
Heather99
I have a Nest and we recently experienced a power outage. Now my heater won’t respond to the nest. I am still without wifi due to the outage. Anyone have any ideas?
Houptee
I will work without wifi. Does it light up and respond to touching it etc or is the power off to the heating system?
Maybe a breaker tripped when power came back on?
Hi Heather99,
Thanks for reaching out — I saw your post and wanted to chime in.
Let's sort this out:
  • What type of Nest Thermostat do you have?
  • Is your thermostat display not turning on?
  • Make sure that the power from your HVAC system at the breaker is turned on.
  • Check for the emergency switch it is usually beside your system. When the power cuts off, it switches to off automatically.
I'm looking forward to your response.
Thanks @Houptee, for your help.
EmersonB
@Heather99 I'm dropping by to ensure that everything is covered here. How's it going with your Nest Thermostat? We would appreciate it if you could share with us the information we're asking above. So that we could take a deeper look.
I appreciate the help, Jenelyn and Houptee.
EmersonB
Hey Heather99,
Just one quick final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need help, we would be happy to keep it open. If there's more we can do, just let us know.
