10-09-2022 10:26 AM
I have three nest thermostats in a vacation rental. During the cold months tenants constantly set at 80 thinking it will warm the house faster. Then leave the room and let it get too hot. Costs me a fortune. Is there a way to set a max temperature? Thanks for any suggestions.
10-09-2022 11:23 AM
I’ll admit right up front that we’ve only been using the Nest thermostat for a short time but I’ve been researching and learning what this device is able to do.
We have only one vacation rental that’s a small condo. This summer a renter set the a/c to 64 for the entire weekend! This prompted me to look for help from the Nest.
One thing to try would be to lock in a range for the heat. Say 67-74. This gives renters some choice but limits the crazy temps set by some. Search for how to lock the thermostat, it’s pretty straightforward.
Our management company tells me this could lead to some negative reviews, so you have to decide, I guess, what’s most important: reasonable utility bills or the occasional negative review.
You could explain to your guests upfront that your concern for the planet has lead you to set a range of reasonable temps for your guests to decide what’s comfortable for them.
10-14-2022 11:00 AM
Hey there smanninen,
I'm just checking up on this thread, do you have any more questions or need any additional help?
Thank you for helping out on this thread, ReluctantLandlo!
Jeran
10-15-2022 06:15 AM
Hey,
Still could not figure it out. Maybe the model thermostat I have does not have these settings.
10-19-2022 11:50 AM
Hey smanninen,
I wanted to jump in, and see if I could be of any help. Do you mind me asking if you have set schedules on your devices? Another option you have is locking the device. Once locked, they would not be able to change the temperature unless they have your pin/access to the app. Please let me know if that helps, or if you have any questions from here.
10-19-2022 07:11 PM
Jake,
Yes I have schedules set up. I just can't figure out how to lock in Max temps. Lmk if you can help me with that.
Scott
10-20-2022 06:55 AM
I copied this info which describes just one way to get to the lock feature.
icon in the top right corner.
. You should now find the option "Unlock" instead of "Lock."
Hope this helps.
10-22-2022 12:51 PM
Thank you @Jeran, @Jake, and @ReluctantLandlo for the help and for sharing some steps.
@smanninen, I want to make sure that you've seen our response. How's your thermostat? Were you able to do the steps above? I'd be glad to hear from you — I'd like to make sure everything is working.
10-25-2022 03:28 PM
Hi smanninen,
Checking back in — how's it going? Still need our help?
10-26-2022 03:40 PM - edited 10-26-2022 03:41 PM
Hello smanninen,
It's me again. Chiming in to check if you have additional questions or concerns as we will be locking this thread in 24 hours.
