12-15-2024 01:11 PM
Any body know what the +, -, and S wires refer to on a trane thermostat wiring?
12-18-2024 03:18 PM
The terminals marked S+ and S- are for external sensors which none of the Nest thermostats support. You can just tape them off.
Sometimes you might see an L terminal which is used for a light on the thermostat. It too can be taped off.
The B terminal on most Trane thermostats is the C terminal.
12-18-2024 03:18 PM
12-18-2024 03:31 PM
Oh man thank you so much! That’s really helpful. One other question. If I have a positive terminal, a negative terminal, and an S terminal I assume all 3 of those are for sensors right? Also, I assume these are probably temperature sensors?
12-19-2024 12:46 AM
