Help with setting locations
Mijnordna
I have two learning thermostats in two locations, but I think I set them up wrong; they both show that they are in the same home, even though they’re not. How can I fix this?
8 REPLIES 8
Follow the steps here on how to create another home in the Nest app and then follow the move instruction.
https://support.google.com/googlenest/answer/9293015?hl=en&co=GENIE.Platform%3DAndroid#zippy=%2Cmove...
Ryan_G
Hey Mijnordna,
Thanks for your help, Patrick_Caezza and MelbaDT.
Ryan
aatienza
Hey Mijnordna,
I'd like to bump in here to make sure that you've seen our response.
Have a great day.
Archie
Thank you for your response. I haven’t had time to address this, but I’m going to tackle this problem today, I would appreciate you keeping this thread open a while longer, thank you.
MelbaDT
Understood. We'll keep this open for a few more days. Keep us posted on how it goes.
Melba
MelbaDT
Hey Mijnordna,
Checking back in — how's it going? Have you had the chance to try the suggestions above already?
Melba
MelbaDT
I haven't heard from you in a while so I'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Melba
MelbaDT
Thanks  again for responding and for providing the link, Patrick_Caezza.
Mijnordna, I wanted to check if you had the chance to go through the steps on the link provided above?
Melba
