Hot water not firing boiler from Nest
Whatola79
Morning,
my heating works fine on the schedule as does boost and the screen goes orange - the schedule doesn’t work on the hot water neither does it boost - the screen stays grey and the app and thermostat say on but the boiler doesn’t fire - I have checked all settings and the heat link clicks on and off but hot water doesn’t come on with boiler - heating is all Ok - any ideas? Thanks Adam
0 REPLIES 0
