11-08-2022 09:37 AM
My hot water setting on my Nest thermostat is set to off and there is no schedule set up. However the boiler constantly heats up my water and hot water is supplied, when I should be expecting just cold water.
This is especially problematic if I am away on holiday and I don’t want the water heated.
Any ideas on how to fix the problem would be appreciated.
Thanks!
11-12-2022 04:53 PM
Hi Ssb83,
Thanks for posting ― let's get this sorted out.
A few questions: what Nest Thermostat do you have? When was the last time this worked properly? What other strange symptoms have you experienced since the problem started? Are there any error messages? If so, what are they exactly? Also, when was the last maintenance check for your HVAC system?
Mel
11-13-2022 12:02 PM
Hi Mel,
It’s the 3rd generation.
i’ve never noticed it before, as I never set a schedule before. HW was always set to on, so only noticing it now for the first time.
There’s no error messages or anything else happening strange.
What is a HVAC system? I had my boiler system serviced a few months ago.
Sarb
11-13-2022 02:54 PM
Hi Ssb83,
Thanks for the update. Could you confirm which country you're posting from?
Mel
11-13-2022 11:31 PM
Hi Mel,
I’m from the UK.
Thanks
