01-29-2022 02:12 AM
Is it possible to simply override the hot water to Off without disrupting the schedule. I just want to end the current time slot without switching the hot water completely off. Like with heating you can just turn it down. Thanks
02-05-2022 06:33 AM
Hi @LaurenceBailey . Currently there is no way to turn the hot water off without adjusting the schedule, if one is set. The hot water schedule only works as an on/off switch, unlike the heating which is also dependent on the temperature.
Except adjusting the schedule you can also turn the hot water schedule on/off by selecting the hot water control on the Nest app, going into the settings for it and then toggling the first option there off. This will disable the schedule.
Keep in mind that you will have to toggle it back on after, to have it follow the schedule again.
