05-12-2022 12:35 AM - edited 05-19-2022 12:16 AM
We changed our internet provider so had to change the two nest 3 thermometers settings. This resulted in them not connecting and having to do factory resets on them both and the heatlink. Since then the hot water wont work on schedule or boost and the only way I can get it to work is by putting the heating and water on manual which is not ideal. The hot water schedule is enabled on the thermometer and it was all working perfectly before the reset so cant be a wiring issue. Any suggestions PLEASE seriously considering getting rid of them
05-16-2022 07:09 AM
05-18-2022 02:18 AM
Hey @Bilk,
Thank you for reaching out! I'm sorry to hear about your issue, but I'll do my best to help you sort this out. Does the heating work as it should from the app?
05-19-2022 12:15 AM
Thanks, yes heating still works find and shows orange in app either by schedule, boost or manual. Hot water however needs to be switched on manually, as even though it says on the app its working it is not
05-19-2022 03:52 AM
I see. Can you send me a picture of what you have in Settings> Equipment on the thermostat's display?
05-23-2022 02:25 AM
Hello there. Just checking in. How's it going with your thermostat?
05-24-2022 12:05 AM
I am struggling to upload images however the downstairs thermostat says
"System Boiler. Heat with on/off"
The upstairs one reads
"System Boiler. Heat with on/0ff. Hot water with on/off"
Thanks for the help
05-24-2022 12:07 AM
Thanks for letting me know. You should be able to find a paperclip icon in there to upload pictures. It would be easier from a computer.
05-24-2022 07:24 AM
No paperclip image when I open this in Chrome on a laptop as there would be in an email only an image of the insert/edit camera I am unable to use and some text editing tools etc.
But please rest assured the text you would see in the picture in the downstairs thermostat is "System Boiler. Heat with on/off" and The upstairs one reads "System Boiler. Heat with on/0ff. Hot water with on/off"
I can email the images somewhere if that help I can attached to email using the paperclip icon 🙂
05-24-2022 07:29 AM
No worries. Thank you very much. Could you tell us please if you were able to reset the schedule on the thermostat for the hot water?
05-24-2022 08:01 AM
Yes i have reset it. It does not work on schedule. If i press boost the heatlink clicks but the water does not heat unless i manually switch on the heating
05-24-2022 08:44 AM
Hey @Bilk. Thanks for the details. It sounds like you might have a stuck valve. If you hear the click sound coming from the Heat Link, it means that it's sending the signal to your boiler. I recommend reaching out to an installer.
05-24-2022 11:54 PM
But then why would it work when i hit manual on the heatlink and why did it happen just after i reset the internet on it? If i turn on the heating via the app it works it is just boost that does not. It is not a valve
05-25-2022 12:14 AM
Could you tell me please if you have a multimeter at hand so we can conduct a continuity test?
05-25-2022 12:35 AM
Can get one for tomorrow what do you need me to do?
05-25-2022 12:46 AM
I've sent you an email with the steps. Let me know how it went please.
05-27-2022 03:29 AM
Hey @Bilk,
Let me know if you still need assistance.
05-29-2022 03:30 AM - edited 05-29-2022 03:31 AM
Hi there, just checking in with you. Do you still need help?
05-30-2022 12:51 AM
Yes. Just got multimeter so will run test today
05-30-2022 06:34 AM
Awesome. Keep us posted with the results. You can reply to the email with all of them.
06-02-2022 07:43 AM
Hi there again @Bilk, just to let you know that my colleagues and I are around and happy to continue the troubleshooting steps if needed. Don't hesitate to let me know if you need any guidance.
06-05-2022 03:00 AM
Hey there, I haven't heard from you in a while so I'll be locking this thread. If you have any new issues, updates on the testing or just a discussion topic, feel free to start a new thread in the community and we'll get back to it. Thanks, AlexD.
