10-14-2022 01:44 PM
I just installed a Learning Nest Thermometer to run my heat only base-board system. I do not have a c-wire for power so must rely on the built in battery. After initiating the device, I saw that it was “low battery”. I charged the unit for a couple of hours and “low battery” went away. How many volts should a fully charged battery read? How long will this charge last? I live in AK and travel up to 3 months at a time. I don’t want this thing dying while I’m gone.
10-19-2022 10:48 AM
Hi Cakinak25,
Thanks for reaching out. The level of charge of the thermostat’s internal battery should be 3.7 V or higher. If the battery drops below 3.6 V, it will be disconnected from your Wifi. If you don't have a C wire, I would suggest looking into the Nest Power Connector for your Nest Thermostat to get constant power.
Edward
10-24-2022 03:45 PM
Hi Cakinak25,
Edward
10-25-2022 05:52 PM
Hi Cakinak25,
Edward
