07-20-2022 10:01 PM
We have two 3rd generation Nest Learning Thermostats sitting 4.5 meters apart on the same wall. We have two thermostats in the same room because we have two zones of electric underfloor heating in the one room and it is useful to be able to control them separately.
We've had this set up for five or six years and been very happy with the way the Nest work in general.
One minor annoyance is that one thermostat always shows the temperature to be hotter by about 1.5 C and The humidity to be higher by about 2%.
Is there a way to fix this?
07-21-2022 01:50 PM
07-21-2022 01:50 PM
Nope
08-17-2022 01:42 PM
Hey there Rafferty,
I know this response is long overdue, but did you have any more questions or need any additional help?
Thank you,
Jeran
08-21-2022 04:10 AM
Hey everyone,
I'd like to jump in here and check if you've seen Jeran's response. Let us know if you need more help by replying to this thread.
Thank you for your help, Jeran.
Ryan
08-21-2022 04:35 AM
It appears that it's not possible to calibrate the thermostats to produce the same temperature and humidity readings. Or have I misunderstood this?
08-22-2022 08:22 PM
Hi Rafferty,
Thanks for the reply.
The Nest Thermostat works independently and could provide a difference in temperature or humidity reading depending on the location and other factors such as electronics and appliances near it.
Check out this link to learn more.
Ryan
08-25-2022 10:04 PM
Hi Rafferty,
Edward
08-26-2022 10:09 PM
Hi Rafferty,
Thanks
Edward
