I think it will work?
mshorey81
I looked through the compatibility checker and I think it will work but not sure about the C wire?  New to the community and hope to be ordering up a Nest Thermostat soon so pardon the noob question.  Thank you for your time.PXL_20230523_180107313.jpgPXL_20230523_182619716.jpg
EdmondB
Hello mshorey81,
Thanks for posting here in the Community. Based on the photos of the wires from your current thermostat, this is a heat pump system. This should be compatible on the Nest Learning Thermostat 3rd Gen with the 2nd stage heating white wire.
The correct wiring configuration for that in Nest thermostat is the following:
Yellow wire on Y1
Red wire on RC or RH
Blue wire on C
Green wire on G
Orange wire on O/B
Brown wire on W1
White wire on W2
Check out this link for Nest thermostat compatibility. Let me know if you have more questions.
Edmond
EdmondB
I'm dropping by to ensure that everything is covered here. I hope that the information sheds some light on the issue. If you have other questions and concerns, feel free to let me know.
Edmond
Thanks for the help here, Edmond.
@mshorey81, I'm checking in to make sure that you've seen our response. Please let us know if you have any additional questions or concerns before we close this thread in 24 hours.
