04-06-2023 06:10 PM
Hi. Anyone would know if my system is compatible to any of the Nest thermostats, please? See photo attached.
04-07-2023 05:45 PM
Are there two thermostat cables in there? It looks like maybe there is one cable with red and white. And another cable with red, white (unused), blue, green and yellow. Anyway, because you have two R wires , one each for Rc and Rh you likely will need the Learning Thermostat.
You can verify using the Compatibility Checker here:
https://store.google.com/us/widget/compatibility/thermostat?pli=1
04-08-2023 03:40 AM
Thanks @sporfrog. I was able to check and it is compatible. Thank you.
04-11-2023 11:48 AM - edited 04-13-2023 12:11 PM
Thanks for posting in the Google Nest Community forum. I'm glad to hear that your system is compatible with our Nest Thermostats. Were you able to install your thermostat already? How's it going?
I appreciate your help, @sporfrog.
04-12-2023 12:04 PM - edited 04-13-2023 12:12 PM
Hi marcog,
I wanted to follow up if you still need help. Please let me know if you’re still having any concerns or questions from here.
04-13-2023 12:13 PM
04-14-2023 06:08 AM
@Jenelyn_O , see my response above
04-14-2023 09:59 AM
Hello there,
I appreciate your assistance here, Jenelyn.
Thanks for getting back to us, marcog. I can confirm that your dual-fuel system, based on the wiring configuration of your current thermostat, is compatible with a Nest Learning Thermostat. Please make sure to follow the same wiring setup with the appropriate terminals.
If there’s anything else I can help you with, please let me know.
04-17-2023 04:39 PM
Chiming in — I just want to check if you still have any questions or concerns, as I'll be willing to take a closer look and assist you further. You can visit this support article for your future reference.
I appreciate your help, Mark.
04-18-2023 04:53 PM
Hi marcog,
