06-22-2022 11:00 AM
I installed nest learning thermostat and received a e73 error no power to rc wire. Checked fuse at a/c unit. Unit does not have a condensate switch. Filter is new. Have approximately 28vac between c and rc. I snipped all wires and reattached to nest. Now I have e79 error no power to c wire. I still have 28 vac between c and rc. Any thoughts? I wouldn't think the connections would be so touchy.
06-29-2022 07:42 PM
Hey GTLong,
Thanks for posting and I'm sorry to hear that you're running into this roadblock installing your Nest thermostat. I want to dig deeper into it.
Quick question — what type of Nest thermostat and HVAC system are you setting up? Also, could you share a clear photo of your original thermostat wires showing the labels of it's terminals?
Melba
07-04-2022 08:42 PM
Checking back in — how's your thermostat now? Still need our help?
Melba
07-05-2022 08:43 PM
Melba
