Issues with Setting a manual heating schedule
Vossy
I am trying to set my heating to work off a manual Schedule I created, which is similar to the hot water schedule I setup.
I want the heating on for 2 hours in the morning and 4 hours in the evening.
I don’t want the use the “Learning” function because I found the heating runs for much longer and is less efficient (which you can argue defeats the object of going for a Learning version of Nest)
My issue is that the heating completely ignores my schedule and I am not sure what else I need to do to keep to a simple schedule without any learning function being active.
Any ideas or suggestions of how I can set up a simple manual schedule which allows the heating to go on and off at specific times that in the other interference from the learning functions?
0 REPLIES 0
