Lock Case Installation
Mike-Y
I am going to install a lock case on my Nest Thermostat. Because I have to disconnect the wires to feed through the back of the case, do I have to reset the thermostat after I reconnect the wires?
Thank you
EdwardT
Hi Mike-Y,
Thanks for reaching out. You don't have to reset your Nest Thermostat, though you would need configure the thermostat for the wiring again after reconnecting the wires.
Edward
EdwardT
Hey Mike-Y,
Edward
