Low battery issues
Ed2022
Do not buy one of these thermostats.  They are very unpredictable and the one I spent over $ 250.00 on is done, in 2.5 months.  Google Nest Support ran me through a bunch of test and then in the end advised me that the thermostat is faulty.
The Agent tried to get me a replacement as it wasn't that far out of warranty.  I even stated I would take the cheaper replacement one, that's currently $ 129.00.   Oh we are so sorry nothing we can do.
Not happy and definitely won't be buying another one.  As I've asked around these apparently fail regularly.
This could have made me a future customer for $ 129 but they refused.
Just ranting, not happy.
20 REPLIES 20
Caarandolph
Yes I am not either thinking about just tossing and getting a whole new thermostat
Hello everyone,
I'm sorry you both have to experience this, and we hope you can have a better time. For your benefit, I'd like to investigate this further and try to look for other options.
@Ed2022, can I have your support ID number so I can review the status?
@Caarandolph, what Nest Thermostat model you have? Could you provide more details about what happened? Also, could you provide a rundown of all the steps you've tried?
I'm checking in to make sure that you've seen my response. Please let us know if you have any additional questions or concerns before we close this thread in 24 hours.
Hello Mark I find that the thermostat doesn’t have the correct read for instance it was set on 75 the house was at 74 and it was still running now it is hotter than normal but my ac has been running non stop for days now when I first got the nest thermostat I called to complain about it the agents really weren’t any help they would ask how the e wires were installed an I needed to send a bill from the ac man I got an ac man to install but they say that anyone can install
Hello Caarandolph,
Thanks for getting back to us with more details, and I'm sorry for the trouble this may have caused you. Let's see what's going on.
Can you provide me with your support ID number so I can see how the troubleshooting or installation went through? That might help. Also, this might be a power-related issue you're experiencing that's causing your AC to constantly run. Please gather the power readings in the Technical Info settings or in the Equipment settings.
Keep me posted.
Checking back in — how's it going? Still need our help?
yes I will send you the readings today
Hi Caarandolph,
That sounds like a plan! I'm eager to hear from you.
Hey Mark after sending the readings were they where they are supposed to be?
Hello Caarandolph,
I'm sorry for the delay. Can you also tell me the status of its Wiring Info in the same settings? This is to ensure that it detects all the wires and if there's a wiring report that has been overlooked. Also, have you tried resetting your thermostat to factory defaults to recalibrate? If you haven't yet, let's give it a try and ensure that its software version is up-to-date.
Keep me posted.
Caarandolph
Vin 36.392V
lin:385
PS:C-385
hello you want a pic of the wiring?
Yes please. In addition, when did you install your Nest Thermostat? Are you still using the batteries that came with it? If you repeatedly get low battery messages from your thermostat, or if there’s another power-related message, you may need to check the C wire connection or install a C wire to provide consistent power to your thermostat and prevent the backup batteries from draining.
this thermostat is still acting weird the house was set to 78 and the house was 79 and the air came on why is this?
@Caarandolph, thanks for keeping us in the loop. Could you please provide your thermostat's current power readings? Do you see any messages or codes in the app? Try to restart your Nest Thermostat and see if there would be any changes.
I appreciate the help, Mark.
Kind regards,
Caarandolph
Vin 36.392V
lin:385
PS:C-385
Caarandolph
Thanks for your assistance here, Jenelyn.
I apologize for the delayed answer, @Caarandolph. Seeing the Leaf icon on your thermostat display when cooling is activated appears to be a programmed temperature feature. Please check its Temperature Schedule for Eco or any related schedule available that would trigger it to activate, remove them, or edit if needed. Then, check the Routines for any thermostat actions that could cause the system to run automatically.
I appreciate your patience. I'm looking forward to hearing from you.
