03-10-2022 05:01 AM - edited 03-10-2022 07:29 AM
Hi there
My heatlink has failed and it is due to be replaced on Monday .
However as there are no LEDs , no Wi fi nothing is working on the heatlink am I still able to put the device into manual mode?
Is there a simple bypass as I cannot seem to find away and if not that is a major flaw in the product.
If anyone knows a way I can crudely turn my heating on please advise.
Surely I do not have to manage without heating for 4 days when my boiler is perfectly functional? If there is no other way to bypass this cheap heatlink box then I think long-term this solution will need to be removed.
It's a Baxi 800 boiler
03-11-2022 03:17 AM
Hey @Gareth5152. You can check if the boiler has an override button or a programmer. If your Heat Link is broken, you can't turn on your heating using Nest.
03-11-2022 03:22 AM
Hi , thanks for the reply but I cannot see one. The problem seems to be there is a lack of override option.
I have controls on the biller but as the heatlink seems to have priority the manual controls do not do not work
03-11-2022 03:25 AM
I see. In this case you could install a temporary, traditional, thermostat to override the system until your replacement arrives.
03-13-2022 06:34 AM
Hi, I wanted to check in. Do you need any further assistance? If so, make sure to let me know.
03-16-2022 08:24 AM
Since I haven't heard from you in a while, I'll have to close this thread. Should anything else come up, please open another thread and we'll take it from there. Have a good one and stay safe!
