12-13-2021 08:03 AM
Hi, I recently bought a house that already has Nest installed. It has a heat pump and oil backup. This is already installed and wired with the thermostat, all I had to do was create my own account for the Nest. However, I can't figure out how to set it up for the dual fuel system (right now only the electric heat pump is the primary). I want to begin using the oil back up as it is getting quite cold in New England. How do I set this up on the thermostat/the app?
Thanks!
12-13-2021 08:14 AM
From the tstat go to settings go, to equipment make the changes you want.
12-13-2021 10:39 AM
I tried that but dual fuel is not an option? Do I have to go to pro settings?
07-25-2022 08:00 AM
Yes, apparently you have to go to Pro settings.
This is sketchy at best, some say you need a C wire others say dont usse a C Wire, still others say the C wire should come from the Nest Power converter and still others say C from the HVAC. Oy!!!
12-13-2021 11:39 AM
I don't think Nest uses "Dual fuel", you have a heat pump primary, with furnace as auxillary, and maybe electric as emergency.
12-13-2021 11:51 AM
Interesting. I watched a popular video with an HVAC pro showing how to set up the dual fuel, but when I tried myself I could not get the same options. Is there a way to set up primary and auxiliary? Every time I go in now, it only gives me the option to set up one- electric (heat pump)
