02-26-2023 12:31 PM
Hey team!
I have a Boiler which heats up baseboard radiators.
Original Two wire T-stat is connected to the EXT+, EXT- inputs on the heat timer.
Controlling the boiler is this unit:
https://www.heat-timer.com/wp-content/uploads/2019/04/DigiElite-SPC_Manual.pdf
Take a look at the manual above.
I see there is a 24VAC, COM, EXT+, EXT-. Therefore I can connect the nest to power, but it only asks for heat, and doesn't shut off at desired temp.
ANY Tips / Advice is appreciated!
Thanks team!!
DOES ANYONE HAVE EXPERIANCE WITH THIS HEAT TIMER CONTROLLER?
03-07-2023 10:03 AM
Hello yhz,
Thank you for taking the time to let us know about your inquiry. I'd be happy to take a look at this for you.
Could you please share with us a photo of your thermostat's wiring? Also, from what country are you posting?
03-10-2023 03:23 PM
03-11-2023 03:47 PM
Hi yhz,
I'm checking in to make sure that you've seen my response. Please let us know if you have any additional questions or concerns before we lock this thread in 24 hours.
