10-13-2022 03:04 PM
https://mashtips.com/fix-no-power-to-rh-wire-on-nest-thermostat/
Copy & paste link above in a browser. THIS ACTUALLY WORKED!!
We tried this solution and it actually worked! Just a small amount of water pooled in the HVAC Float Switch. Drained it and air conditioner is now working.
Check HVAC Float Switch
The condensate overflow switch located near the Air Handler unit, inside your home. This is to protect your home from possible water overflow from the HVAC unit. If your drainage pipe is not clean, or if there has any clog, the overflow switch will disconnect the power and turn off the AC.
10-18-2022 02:20 PM
Hey there JF2968,
Thank you for posting this solution! I know I've seen this error floating around, so hopefully it helps other users as well! I leave this thread open for a few days in case anyone wants to comment on this.
Jeran
10-21-2022 02:54 PM
Hi JF2968,
Edward
10-24-2022 03:28 PM
Hi JF2968,
Edward
