06-07-2022 08:22 AM
When I use the Google Home app and try to add the Nest device, it brings me to the Nest Login page with no option to sign in using google. Instead it asks for a username and password, which I do not have since I just use Google to sign into the Nest app.
06-11-2022 02:11 PM
Hi connorh21,
Thanks for reaching out. I'm sorry to hear that you're having an issue with linking your Nest devices to the Google Home app. I'd love to know more about this and I have a few questions:
You could also click on this link to learn about setting up your Nest devices on the Google Home app.
Edward
06-14-2022 02:21 PM
Hi connorh21,
Edward
06-14-2022 03:00 PM
Hey Edward, yes I am having the same problem still.
06-14-2022 03:18 PM
Hi connorh21,
Thanks for the update. Could you tell us what devices are you trying to add to the Google Home app? Also, please try logging in using your Google account's username and password.
Edward
06-17-2022 06:56 PM
Checking back in — how's it going? Have you had the chance to try Edward's last suggestion above?
Melba
06-20-2022 06:24 PM
Melba
