Need help figuring out if my current wiring is compatible
caridoman
I went through the compatibility checker and the result was that i need to contact support to verify if my thermostat wiring is compatible with Next.  I've attached a photo of my current configuration.
You will need to answer a question.
Do you have a Heat Pump, If yes, your wires are:
R is Red Wire, you can ignore the Rh to Rc red jumper wire.
G is Green Wire.
Y is Black Wire
O/B is White wire
If you have a conventional system with furnace your wire are:
G is green wire
Y is black wire
W is White Wire
AC Cooling Wizard
thank you for the quick response.  i don't have a heat pump so i'll follow the conventional system wiring.
Hello there,
Thanks for the help, @CoolingWizard.
@caridoman, I wanted to check and see if you had a chance to install your Nest Thermostat. How's it going? Still need our help? Please let us know so we can assist you right away.
Installation went well - thanks for the support
Hi caridoman,
Awesome! I'm glad to hear it was installed successfully. So it looks like we can consider this one complete, and I will lock the thread within 24 hours unless I can help out with anything else.
