Need help with nest
Rickm2
Have a zone relay zsr106 120v  how do I get my nest thermostat to work with this have baseboard heat hot water please help
chaconmorales
Hi Rickm2,
Thanks for reaching out to the Community. I am sorry that you are having issues with your thermostat compatibility and installation. But no need to worry, help's here!
Based on the information provided, your system is not compatible with the Nest Thermostat, however you may need to contact a Nest pro and have them check your system to confirm if it is compatible. In some cases it is necessary to rewire or check the best wiring configuration for the devices to avoid causing any damage in the system.
You can also check the following article to verify your Nest thermostat compatibility.
Please keep me posted.
Mario
