Need help with wiring
Vin44
Currently looking to replace a wired Midea thermostat that has a connector with 4 unlabeled wires that are colored. Is this possible to split up these wires and connect them to the nest base connectors? If so, help is greatly appreciated. I’ve attached a pic of the wiring that is connected to the current thermostat. Thank you
Your current thermostat is not compatible with any of the Nest thermostats as it uses a proprietary interface that Nest doesn't support.
MelbaDT
Appreciate your answer, Patrick_Caezza.
Vin44, I'm jumping in to check if everything is good here. You can also check your system’s compatibility before purchasing a Nest thermostat with our online Compatibility Checker or check this link: https://bit.ly/3qZ6OQ1
Melba
MelbaDT
Hey Vin44,
Checking back in should you still have some questions here. Feel free to reply to this thread.
Melba
MelbaDT
Melba
