Nest 3rd gen on problem
Billyfraser
My heating is set to come at 4pm to heat to 22, it comes on and  heats to 22, but after it cuts off it won’t come on again until I turn the dial my self. I want it to come back on after the temperature drops to 21.
I hope I have explained it correctly
EdwardT
Hi Billyfraser,
Thanks for reaching out. It’s normal for your home’s temperature to vary slightly (typically one or two degrees) above or below the temperature set on your thermostat for a short while. This is often due to the built-in delay for turning on your system. This delay is commonly called the maintenance band, deadband, differential, or temperature swing. The delay is usually just a few minutes, but it’s to prevent unnecessary wear on your system and help save energy.
Edward
aatienza
I appreciate the help, Edward.
Archie
aatienza
Archie
