09-03-2024 11:48 AM
Hello, I have the Nest 3rd generation.
This controls my dual-energy system (bi-energie in french), which includes my heat pump which produces heat and air conditioning, then between 3 deg C and -12 deg C, controls the heating elements in my ventilation duct, and if the temperature is lower than -13 deg C, check my oil furnace.
I will power my system in the event of a power outage with an inverter generator that will be dedicated to my oil furnace only.
How can I ask Nest to only run my oil furnace since the other components will not be powered?
09-06-2024 02:39 PM
Hi commequidira,
Thanks for posting in the Community! I can definitely help you to change on your Nest Learning Thermostat the heating source. Let’s try the next steps:
Let me know how it works,
Axel.
09-08-2024 09:25 AM
Hello, thanks for the info. I followed your instructions but it leads to further and with more choices, it offers me to do tests. It is not clearly indicated to choose a specific equipment to heat.
After your point 3, I get the YOUR SYSTEM section, which lists the equipment. I only have the choice to continue by clicking CONTINUE, I arrive at another page: EQUIPMENT SETTING, at this point I am offered - Heat type
-Heat pump
-Dual energy
- Inst PRO
-Precedent
Is it like just doing tests? I don't seem to have the possibility to choose the heating I want to use? It's annoying.
09-08-2024 11:41 AM
Hi commequidira,
Thanks for replying! Sorry to hear that the steps above didn’t let you choose which heating source you want to use. Let’s try some other steps:
Let me know how it works.
Axel.
09-10-2024 03:42 PM
Hello AxelD,
thank you for the information, I think I found a way to do it. From the Google Home app, I can tell it to switch to alternative heating without using the heat pump.
I will eventually test and of course, if there is a power outage, I will have to make sure to power the house wifi.
to test of course! THANKS !!
