12-02-2022 04:05 PM
I recently added a heat pump to my forced air furnace. Everything works great, except Early On.
I have tried all of the recommended settings I could find online. I hope it it still learning how long it takes to heat the home, but my history shows that the furnace is only kicking in at the scheduled heat time of 6:30. There are no other indications it is still learning. I would like it to be at temperature by 6:30.
it is cold enough outside now that the heat pump isn’t engaged at all. This is only using the furnace, which is setup aa auxiliary heat.
12-08-2022 07:07 PM
Hi Jeff42,
Thanks for reaching out. I'm sorry to hear that you're having an issue with the Early-On feature. I'd love to know more about this. When did you install the Heat Pump? Early-On continually adapts to the weather forecast and how fast your home heats up or cools down. It adapts to improve its Time-to-Temperature estimates and keeps you comfortable while also helping you save energy.
Edward
12-12-2022 09:19 AM
Chiming in to see if you still need assistance with this. Let us know if you have additional questions ― we'd love to help.
Mel
12-13-2022 10:02 AM
Mel
12-13-2022 11:03 AM
Hera pump was installed in early November. When it was installed we set the temperature to be the same 24/7. It was only when it started to use the furnace that I reenabled the schedule. Early on gave no indication it was working. The furnace kicks in exactly at the scheduled time.
I have tried many settings, including home/away, which I don’t like.
Currently Time to temperature doesn’t show anything. The screen only has a done button.
I waited a while before replying to this to see if it just needed time.
12-14-2022 09:52 AM
Hi Jeff42,
Nest thermostats detect what wires you have inserted into the connectors and use System Match to tell what kind of heating and cooling system you have. If Early-On isn’t compatible with your system, Early-On settings aren’t available in the app or on your thermostat.
When Early-On settings aren’t available, it may mean:
Check what kind of system you have installed. Then, check your thermostat wiring:
Check this link for more details about Early On.
Mel
12-14-2022 08:09 PM
The Early on settings are all there. It just doesn’t start my furnace any earlier than the scheduled time.
My gas furnace is setup as the auxiliary heat source. But from what I understand, it is supposed to be.
01-11-2023 03:27 AM
I have the same setup and seem to be having the same issue. Have you found a solution?
02-06-2023 08:08 AM
Hello folks,
I'm sorry for the late response. I know it has been a while, but I wanted to ensure that everything was covered here.
If you both have the learning thermostats (Nest Learning Thermostat and Nest Thermostat E), Please make sure to disable the auto-schedule and the Home and Away Assist. These settings will affect the early-on learning of your schedule as they're programmed to adjust automatically. Please let me know if that helps, or if the issue still persists.
Thanks for helping here, Mel.
02-06-2023 05:12 PM
Thanks for reaching out. I was able to figure out that the reason early on was not working for me was that I was re-adjusting some of the heatpump settings in Nest for a few days trying to find my preferred low temperature when it would switch to gas. It seemed like any time I changed settings, the Nest would reset the "learning clock" and it would not execute early on. Once I left my settings alone for about a week, early on started working as expected.
02-07-2023 01:09 PM
I am glad to hear everything is working properly from here. With that being the case, I am going to lock the thread in 24 hours. Please let me know if you have any further questions from here, as I would be happy to review.
