11-01-2021 09:09 PM
11-03-2021 02:24 PM
Hey, I have this exact issue. Although sometimes I get the E102 error as well. I called Google and they said they think I have a bad base. Of course I’m out of warranty. I’ve had this hooked up the same way for over 2 years and now I have the problem. Everything is correct on the heater side. My basement nest E works fine for heat. I wonder if there’s a way to trick it to keep the heat on the main floor
11-05-2021 04:19 PM
I purchased a new base had the same problem with it, out $50.00
11-05-2021 06:58 PM
Yea I am not very confident it will work. I did someone else in another forum with a similar issue and replacing the base did fix their problem. I will update when I have more. I temporarily replaced it with my old mercury thermostat. No battery required haha
11-05-2021 04:18 PM
I was able to get mine to run by putting a short piece of wire in W1.
Moving the White wire from W1 to W2.
Now the heater works as Heat2
11-05-2021 06:40 PM
Unfortunately this still isn’t kicking my heat on; I’m probably going to have to put my Nest from the basement upstairs and go without heat down there. These things have become giant pieces of crap. I remember loving them but why can’t they just work... Does Google even respond on here anymore?
11-05-2021 07:01 PM
I’m confused as to how this would work. The problem is that Rh is greyed out. Not W1…
11-05-2021 06:22 PM
W1 wire is just a short wire that doesn’t connect to anything? Just holds the connector open so it thinks a wire is connected?
11-05-2021 08:10 PM
Yes, its just a 1 inch piece that goes nowhere, but without it you get a error code
11-06-2021 03:52 AM
I wish that worked. Heat 2 was running but my thermostat still didn’t kick on.
11-06-2021 06:47 AM
Heat 2 kicks on 3 degrees higher, try that
11-06-2021 08:06 AM
It’s trying to run just not; says it’s heating heat 2 on the Nest. Just not the boiler on.
