01-15-2024 02:35 PM
I have a Burnham IN5I Boiler and I installed a Nest Thermostat with a two wire setup (from original thermostat). The two wires are connected to W and R on the thermostat.
I keep getting the message "Wi-Fi Disconnected" and error "Install stable power source". It also has a a "Note: N260". As far as I can tell, this means that I need to add a Nest Power Connector to the boiler.
On my Burnham boiler, I think I need to connect the Power Connector to the R8222K Thermostat Isolation Relay. Unfortunately, the relay is not labeled so I cannot figure out how to connect the Power Connector.
Can someone provide guidance?
Thanks!
02-03-2024 02:19 PM - edited 02-06-2024 09:50 AM
Hello ultrakiss,
It sounds like you're experiencing some challenges with your Nest Thermostat installation on your boiler. The "Wi-Fi Disconnected" and "Install stable power source" messages, along with the N260, indeed indicate a power-related issue.
If you believe connecting the Nest Power Connector to the thermostat isolation relay is the solution, it's crucial to ensure a correct and secure connection. Since the relay is not labeled, it adds an extra layer of complexity. Here's a general guideline on how you might proceed:
I hope this helps, and let us know if you have more questions.
02-03-2024 05:17 PM
Hello Mark,
Thank You for your response. That information is helpful. Most likely, I contact a local HVAC technician for help.
ultrakiss
02-06-2024 09:58 AM
Hi ultrakiss,
You're welcome! I'm glad the information was helpful. Consulting a local HVAC technician is a great idea for personalized assistance. If you have any more questions or need further guidance, feel free to reach out.
Warm regards,
