06-07-2023 06:16 PM - edited 06-12-2023 05:21 PM
Looking for help.
maybe @Patrick_Caezza can help here.
I have a nest learning thermometer that controls both AC & heat via zone 3, but no C wire to provide continuous power to the Nest unit (was running off of Rh wire for about 9 months). I bought a Nest Power Connector but I’m not sure about how to wire it to the Taco sr503-exp. The installation guide from Nest says that AC+Heat units should have an R, W and Y wire, but as you can see in the picture, I only have R and W. Should I try connecting it anyway, or will it fry the board?Please help.
06-12-2023 06:47 PM
You have one of the newer Taco Switching Relay boards with a C terminal for each thermostat.
You should be able to install the Power Connector like this.
06-13-2023 09:01 AM - edited 06-13-2023 10:12 AM
Thanks @Patrick_Caezza two questions:
1.) My system is for both AC and Heat, will this set up still apply?
2.) Once I set up the adapter do I switch the wires in the nest thermostat housing, moving the wire in the Rh spot over to the C spot?
06-17-2023 02:48 PM
@MrDrewT, thanks for posting here in the Community forum. The answers to your questions are the following:
Let us know if you have any other questions. We're happy to help.
06-20-2023 02:51 PM
Hi MrDrewT,
I wanted to check and see if you are still in need of any help. Please let me know, as I would be happy to assist, and answer any questions you may have.
06-21-2023 03:03 PM
