12-22-2022 07:01 AM - edited 12-22-2022 07:02 AM
Hello friends,
I have two separate systems for heating and cooling. Cooling is one zone AC; Heating is 5 zone gas powered boiler with baseboard.
I have 6 honeywell programable thermostats that I am in the process of replacing to Nest. I have two Gen 3 learning, 1 Nest E and two Nest Thermostat. I have eliminated one honeywell by combining heating and cooling into a single gen3 learning. All remaining thermostats are heating only.
I am anticipating a "c wire" problem when I install Nest (non E, non learning). I have a Nest power connector. Need help from the community to avoid the "c wire" problem.
The 5 heating zones are controlled by a Taco SR 501 switch relay
Mfg manual -> https://www.tacocomfort.com/documents/FileLibrary/SR501-845RP102-105.pdf
reference -> https://cdn.shopify.com/s/files/1/0533/4922/0503/products/Taco-SR501-Switching-Relay_455x571.jpg?v=1...
Actual -> attached...
Here are my questions...
1 - W and R looks straightforward. Is it sufficient to connect Nest Connector C to the empty COM port on top of the relay?
2 - The thermostat where both independent systems are connected to gen3 learning has Y,Rh,G,W,RC wires. Would adding a nest power connector to the heating system cause any issues with this thermostat?
12-22-2022 03:35 PM
If you can pull new 5 conductor cable to each tstat then you do not need the power adapters and just put RWC from Taco to RWC on Nest.
If you dont want to pull wire then you need a power adapter for each Nest
Except the one you already have working the Learning Nest it doesnt need one it gets power from the AC system.
To wire the power adapters you take off the R W from Taco and connect to R W on adapter.
Then the R W C outputs of the adapter go to the Taco R W C top screw terminals.
12-22-2022 04:48 PM
Awesome. Thank you so much. Will give it a try this week.
Since one with AC has Rh and Rc and the Rh is coming from the same taco, should I disconnect its Rh and let it get power from Rc?
12-22-2022 05:30 PM
Also, do I need one nest power connector per thermostat? I was hoping one would do for all 5.
12-26-2022 02:47 PM
@AndroiderΩ, how's it going with your Nest Thermostat? Still need our help?
Edward
12-29-2022 02:51 PM
Hey AndroiderΩ,
Edward
a month ago
Hi AndroiderΩ,
Edward
a month ago
Thanks for checking. I am not sure how to proceed. Will try and post a detailed diagram and photos to seek additional help from this awesome group.
a month ago
Pull new thermostat wire to each Nest with 5 conductors in the cable otherwise you will need a separate power adapter for each Nest.
3 weeks ago
@AndroiderΩ, I'm checking back in. Were you able to try the steps provided by Houptee? Keep us posted.
Edward
3 weeks ago
Hi AndroiderΩ,
Edward
2 weeks ago
I appreciate the help, Edward.
Archie
2 weeks ago
Thanks for all the help and responses. I don't have any questions at this time.
2 weeks ago
I am glad to hear everything is good to go from here. I am going to go ahead and lock the thread at this time. If you do have any questions in the future, please feel free to create a new post.
12-22-2022 06:17 PM
You need one per thermostat because they each connect directly to the R and W of each Nest, then the adapter outputs to R W C to turn on each Taco
Leave the learning nest wired as it is. Do not put a power adapter on that one. You have to keep Rh and W connected because the Nest is basically just a switch, it connects RH to W when the Nest calls for heat, and starts the circulator pump.
